Highlight BBCode is a simple BBCode that will display the content with highlight color combination. BBCode is very simple to use, and it allows you to add attributes to set text and background colors for highlighting.
There are two formats for this BBCode:
Default, using default colors:
[highlight]the text to highlight[/highlight]
Custom, specify colors to use:
[highlight color="red" background="yellow"]the text to highlight[/highlight]
Here is the screenshot from the forum topic with 3 examples for highlight BBCode use:
To configure default highlight colors, open plugin BBCodes page, Defaults panel and section Highlight has two color settings for the default BBCode colors.
