Conditionally disable voting using filters ArticleKnowledge Levels DeveloperProductGD Rating SystemPosted onMarch 30, 2019November 16, 2020 You must be logged in to read this. Click here to login. CategoryTutorials 0 0 439 Rate this article You are not allowed to rate this post. Related Articles Control who can vote for specific rating items Knowledge Levels DeveloperIntermediateProductGD Rating SystemPosted onMarch 16, 2021CategoryTutorials Scheduling topics to publish in the future ProductGD bbPress ToolboxPosted onAugust 25, 2020August 25, 2020CategoryTutorials Check if the user is online from code ProductGD bbPress ToolboxPosted onJuly 7, 2020CategoryTutorials Additional HTML templates ProductGD Mail QueuePosted onJune 8, 2020June 9, 2020CategoryTutorials Setup rich snippets for rating items Knowledge Levels IntermediateProductGD Rating SystemPosted onMay 19, 2020November 16, 2020CategoryTutorials
It will work in free edition. You can add code into MU plugin – https://support.dev4press.com/kb/article/adding-custom-code-into-must-use-plugin/ or theme functions.php file. Log in to Reply
which php page are we add this code?
is this code working in free edition?
