SEO Tweaks
This is a simple feature that only tweaks several SEO-related things that don’t fit with the main SEO feature.
Private Topics and Replies NoIndex
There are two options to set Robots Meta to NoIndex. Plugin will not allow visitors (and with that, search engines) to access those topics and replies, but, there is no point of having them even try to index them, so it is highly recommended to enable NoIndex.
By default, bbPress is setting all sorts of links in the forums to add ‘NoFollow’ value to REL attribute. With GD bbPress Toolbox Pro SEO Tweaks, you can disable this, and stop bbPress from adding ‘NoFollow’ links.
