gdrts_render_custom_emotes_block()
gdrts_render_custom_emotes_block($atts = array())
Description
Render emote this block for specified rating values and with custom settings. This function is not rendering rating block (active or disabled), it just simply shows the rating values as a emotes block, nothing more. It is useful for showing rating in any place, where you already have rating value, and there is no need to have full rating block displayed.
Parameters
  • $atts: array with display settings.
$atts array
  • series: name of the emote series, default: default.
  • elements: associative array, key is the name of the series elements, value is the number of votes.
  • style_type: render style: image.
  • style_name: name of the style element, default: emoji-one.
  • style_size: size in pixels for individual emote elements.
  • style_theme: theme for the thumbs block, default: standard.
  • style_class: additional CSS class to add to the block.
  • show_labels: show labels for each emote icon.
  • show_percentage: show percentages instead of the absolute votes values.
  • title: custom text to add to the wrapper DIV title attribute.
Examples
Display rating 4/5 with this code:
<?php echo gdrts_render_custom_emotes_block(
        array('series' => 'default',
        'elements' => array('funny' => 2, 'happy' => 3, 'angry' => 3))); ?>
You must be logged in to rate this.
Leave a Reply
