gdrts_render_custom_thumbs_block()
gdrts_render_custom_thumbs_block($atts = array())
Description
Render thumbs block for specified rating values and with custom settings. This function is not rendering rating block (active or disabled), it just simply shows a rating value as a thumbs block, nothing more. It is useful for showing rating in any place, where you already have rating value, and there is no need to have full rating block displayed.
Parameters
  • $aatts: array with display settings
$atts array
  • up: number of UP votes.
  • down: number of DOWN votes.
  • style_type: render style: font or image, default: font.
  • style_name: name of the style element, default: thumb.
  • style_size: size in pixels for individual thumb elements.
  • style_theme: theme for the thumbs block, default: compact.
  • style_class: additional CSS class to add to the block.
  • labels_up: title for the Thumbs Up.
  • labels_down: title for the Thumbs Down.
  • title: custom text to add to the wrapper DIV title attribute.
Examples
Display rating 4/5 with this code:
<?php echo gdrts_render_custom_thumbs_block(
        array('up' => 4, 'down' => 6)); ?>
You must be logged in to rate this.
Leave a Reply
