Manual rating block theme integration
This video show how you can add rating block to the theme template, customize the manual integration functions, custom styling, and positioning.
2 thoughts on “Manual rating block theme integration”
  1. Hi Thank you for the wonderful job you have been doing.
    I have a question,
    I have a number of uploaded files displayed in a table on my front page. How do I manually integrate the plugin to display the rating block for each file in the last column of the table. I am using twenty sixteen theme.
    Link: seneflshare.net
    Thanks
    • The knowledge base contains plenty of articles already on using the functions for such integration, it is only the matter of setting the proper item type and ids for items. In the case of attachments, rating entity is ‘posts’, the type name is ‘attachment’ and ID is attachment ID.
