Manually add rating block with PHP
The plugin has few ways to add rating blocks into the website. But, if that is not enough and you want to manually position rating blocks and set them differently, you can use PHP functions to do just that.
Intro
Before we go on, make sure you understand basics of GD Rating System objects and terminology:
To get parameters for different rating methods to use with these functions, check out the articles about each rating method
Main function
Function gdrts_render_rating is the main rendering function. This function can render rating block for any rating item and any rating method.
Function syntax
gdrts_render_rating($args = array(), $method = array())
- $args – list of settings related to rating item.
- $method – list of settings related to rating method, and depends on the rating method set with $args.
$args is array with following elements:
- echo: display or return rendered rating block. Default: false.
- entity: rating type entity.
- name: rating type name.
- id: rating item real ID.
- item_id: rating item ID from ratings table, assigned once when rating item is first requested and added to database.
- method: rating method: stars-rating, thumbs-rating, like-this or stars-review.
If you specify item_id, you don’t need entity, name and id.
$method is array with elements depending on the method from $args array. You can check out individual rating methods articles for list of parameters.
Examples
Here are few examples for this function.
Post with ID 10, Stars Rating method, default rendering settings
gdrts_render_rating(array('echo' => true, 'entity' => 'posts', 'name' => 'post', 'id' => 10));
This will display rating block, and all stars rating settings will be taken from plugin settings and custom rules settings.
Page with ID 5, Stars Review method, custom rendering settings
gdrts_render_rating( array('echo' => true, 'entity' => 'posts', 'name' => 'page', 'id' => 5, 'method' => 'stars-review'), array('template' => 'expanded', 'style_size' => 40) );
This will display rating block, and stars rating settings will be taken from plugin settings and custom rules settings. Only template and stars size will be set by this function.
Posts specific functions
This function works only for posts, pages and custom post types. It can also detect current loop post.
Function syntax
gdrts_posts_render_rating($args = array(), $method = array())
- name: post type.
- id: post real ID.
- method: rating method: stars-rating, thumbs-rating or stars-review.
If you specify item_id, you don’t need name and id. If you don’t specify name and id, and you don’t specify item_id, plugin will take the current post from the WordPress loop.
Examples
gdrts_posts_render_rating(array('echo' => true, 'name' => 'post', 'id' => 10));
Current post from loop, Stars Rating method, custom template
gdrts_posts_render_rating( array('echo' => true), array('template' => 'light') );
This will display rating block by taking current post from loop, and stars rating settings will be taken from plugin settings and custom rules settings. Only templatewill be set by this function.
Current post from loop, Stars Rating method, all defaults into variable
$rating = gdrts_posts_render_rating();
This is minimal function call, it doesn’t display rating block, it places it into variable, detects post from loop, and uses all default settings for Stars Rating.
$rating = gdrts_posts_render_rating(array('echo' => true));
This is minimal function call, it displays rating block, detects post from loop, and uses all default settings for Stars Rating.
7 thoughts on “Manually add rating block with PHP”
You must be logged in to post a comment.
How can we translate the text?
The plugin supports translations system in WordPress, and you can create PO/MO translation files to use. POT file with all strings is in the plugin root.
This code shows the ratings even if the user has chosen hide in the “Display Rating Block” dropdown when creating the post. How can we add the ratings using custom code while observing the users selected option?
You can’t. Metabox settings are related to automatically added rating block (and which method to use). Using functions or shortcodes doesn’t use these rules because it is unrelated.
Can the selected value be exposed so I am able to wrap this code in a conditional statement?
You can wrap these function calls in any conditional check, just like any other function.
Right, in order to do that I will need access the value the user has selected… Is it possible to please tell me how I can access the selected value, so I can create a conditional statement to prevent the ratings from showing if the user has selected hide?
