Secondary action toolbar for Topics and Replies
Every topic and reply displayed in bbPress has an action toolbar above the content area with actions to edit, reply, close… and this can be expanded too with new actions. But, depending on number of actions and the width of the page, this area can become crowded.
GD bbPress Toolbox Pro 4.0 brings the secondary action toolbar underneath the topic or reply content. And, you can move some default actions into this toolbar, and you can place all plugins own actions there too. This toolbar is active by default and it can’t be disabled, but if there are no actions in it, it will not be displayed. Toolbar uses similar styling as the bbPress default toolbar uses, and it has own CSS classes you can use to change it through your theme. Image below shows the secondary toolbar with Edit and Reply options moved, and with GD bbPress Toolbox Pro actions Lock, Thanks, Quote.
Secondary Toolbar
Secondary Toolbar
Every tool that adds action links now allows you to select Footer for action location: Quote, Thanks, Lock. And you can move default actions from the Topics & Replies Settings panel.
