Dashboard
The Dashboard is the main panel to get quick started with the SweepPress plugin features, get quick access to the quick and auto sweeper, view database status and more.
Dashboard Panel
Dashboard has 4 widgets. The exact widgets will be slightly different between Lite and Pro plugin versions.
Plugins Status
This widget shows various status messages, including the status of the plugin license.
Plugin Features
This panel shows status of various plugin modules and counts for the available sweepers, along with the count of registered sweeper jobs.
Database Status
This widget shows overview of the database tables, sizes, rows and more, including the estimation of the database size, relevant for some of the plugin features. Statistics shows all database tables stats and WordPress Core only database tables stats.
Auto/Quick Sweeper
This widget contains both Auto Sweeper and Quick Sweeper. To get more information about them, check out this article.
