Plugin Maintenance and Removal
The Tools panel, is very similar between all Dev4Press plugins, with several pages all plugins have, and some additional pages specific to individual plugins.
Tools Panel
Plugin Maintenance
Recheck and Update
From this page plugin will run same process that is run on every page update.
Cache and Storage Purge
From here, SweepPress can remove cached sweepers data, cached data related to meta panels, and all the storage related to tracking for CRON jobs, options and metadata.
Export Settings
All plugin settings will be exported into encrypted JSON file.
Import Settings
All, or selected, plugin settings can be imported from the unmodified encrypted JSON file.
Plugin Reset
Reset / Remove
If you want to reset plugin settings, or remove all the settings, and deactivate the plugin, you can do it from this page.
