SweepPress Pro: Plugin Introduction
SweepPress is an easy-to-use WordPress plugin built around 45 different Sweepers for database cleanup , support for WP-CLI, and WP REST API to perform the cleanup operations. The plugin also features a powerful WordPress Metadata, Sitemeta and Options database table management panel, Database Management, CRON Control, Scheduled Jobs, Sweeper Monitor and more.
