Back to Forum
A few suggestions for dev4press
Published on: April 10, 2012 at 11:46 pm · By: Robert S
Hi Milan,
Have several suggestion for dev4press website:
1) Documentation page needs improvement. I always get a 404 when going past last page. Filter does not seem to work properly – eg: if I do a search for shortcodes on xScape Core | All documents – then it returns empty.
2) I would like to see a more detailed Changelog per release of your products – rather than something like “Several bugs fixed”. I would like to have a better understanding of the impact a new release will have on my sites.
3) I would like to see a facility to search the Forums. At the moment there’s no easy way to search the forums – and there might be times when something has already been resolved which people could find – and therefore save yourself some work.
I know that some of these suggestions have probably been mentioned previously and that you’re a busy man and focusing on product improvements. However feedback is always a positive thing from users.
Viewing 7 replies - 1 through 7 (of 7 total)
  • #15955
    Thanks for the suggestions!
    1. This will be sored soon, most of it is fixed, and I plan to have that online next week.
    2. Detailed change logs are included for each plugin/theme and on their download pages.
    3. That is coming also. I am still testing search plugin for this, and I hope to have it in next website update also.
  • #15957
    Hi Milan,
    Re Changelogs – eg if I try and bring up changelog for xScape Core – this is what I get: (nothing on 1.8.2.4)
    1.7.7.2 | 2011.06.15.
    xScape Framework 1.7.7.2
    1.7.7.1 | 2011.09.10.
    xScape Framework 1.7.7.1
    1.7.7 | 2011.09.08.
    Shared templates and loop elements
    1.7.6 | 2011.08.25.
    xScape Framework 1.7.6
    Removed Superfish shadow image and CSS
    1.7.5 | 2011.08.22.
    xScape Framework 1.7.5
    1.7.4 | 2011.08.02.
    xScape Framework 1.7.4
    1.7.3 | 2011.06.27.
    xScape Framework 1.7.3
    1.7.2.1 | 2011.06.14.
    xScape Framework 1.7.2.1
    1.7.2 | 2011.06.14.
    1.7.1 | 2011.06.09.
    xScape Framework 1.7.1
    1.7.0 | 2011.06.06.
    First official release
    1.7.0 | 2011.06.06.
    xScape Core Changelog
    close
  • #15961
    Yeah, I am behind on some change logs. I will try to update them all soon.
  • #15964
    Milan,
    Ideally the changelog is in place at the time of the release. Most themes seem to have changelogs a few months out of date.
    Cheers,
  • #16062
    Hi Milan,
    as I don’t have Premium support- I can’t get into the GD Star forum, still, I had a suggestion:
    Amazon has a “you may also like” for when people rate an item.
    How about if GD Star 2 has a similar ability- since GD Star can see by cookie/IP what someone has rated something, the admin could have the ability to display correlations between different articles that have been rated to the public via a widget, shortcode, etc.
    Or, is that already in the works?
  • #16072
    This is in the plans, but I doubt it will end up in the first 2.0.
  • #16075
    Good to know that it is in the plans, this would be a Great feature!
    Thanks!
  • The topic ‘A few suggestions for dev4press’ is closed to new replies.
