Best way to view a summary of votes?
Published on: May 5, 2023 at 7:07 pm · By: bearstar
I am using the plugin to assemble start ratings on a custom post type. I’d like to view a report of all ratings to see which post is best. If this is not possible with the Lite version, what assemblage of pro plugins is needed to view a summary of all votes for the customer posts and the ability to see which is best?
  • #75479
    Do you need this for analysis, not to be displayed on the page? There is an Analytics addon for the Pro version, that can export votes and ratings into JSON and CSV files. The addon is not free, so you need to have Pro version of the plugin and also buy the addon, or get the license for Rating Plugin Club (includes the main plugin and all Pro addons). More about the addon: https://addons.dev4press.com/analytics-addon/.
  • #75604
    Since our voting is in progress, is there any interruption to the existing functionality or logs by upgrading to Pro and installing the analytics add-on?
  • #75609
    Lite and Pro versions are fully compatible in every regard, Lite version just lacks some of the features, the core of the plugin, database and other important stuff is 100% the same.
  • #75614
    Topic split to new one and moved to correct forum. This topic is now closed:
    https://support.dev4press.com/forums/topic/analytics-best-way-to-view-a-summary-of-votes/
  • The topic ‘Best way to view a summary of votes?’ is closed to new replies.
