Do you offer any WP custom work to replace GD Star Rating with GD Rating System?
Published on: August 2, 2017 at 1:28 am · By: csreport
We had a developer install GD Star Rating throughout our site and now he dissapeared and if we disable the GD Star Rating plugin our website crashes. Looking for a developer to remove the GD Star Rating and replace it with the GD Rating System. Thanks!
  • #56580
    Can you tell me more about what you were using from GD Star Rating, standard or multi ratings, thumbs, what kind of integrations were made.
  • #56581
    Hi Milan,
    Thanks for the reply. Our dev that disappeared hard coded the GD Star Rating in some of the pages like Reviews, Home Page and Free games etc. www.casinoscamreport.com is the site. We purchased the GD Ratings System but without knowing much about WP coding it is impossible to make those changes ourselves. Thanks, Rick
  • #56582
    I have checked out your website, and it looks like detailed integration. But, it can be converted. The problem at this point is that you use multi stars rating for rating the casinos (with 3 elements: Software, Support, Promotions items), and currently there is no tool for transferring multi rating data from GD Star Rating to GD Rating System. This is in development for the next major 2.4 version (scheduled for September). Also, GD Rating System Pro will require Multi Ratings Addon purchase to work with multi ratings.
    Once the data transfer tool is done, we can use it to convert old data to new plugin format, and after that, I can work on the migration of your code to the new plugin. For more information about that, you can contact me via email: support@dev4press.com.
  • #56583
    Thanks Milan,
    I sent you an email.
    Rick
  • The topic ‘Do you offer any WP custom work to replace GD Star Rating with GD Rating System?’ is closed to new replies.
