Back to GD Mail Queue (Lite) Forum
Export/Import not copying Queue settings?
Published on: May 22, 2019 at 12:23 am · By: Tony
I used the export and import tool to copy settings from my test site to live site.
The queue settings appear not to have copied across.
No great problem as it was simple to edit by hand.
  • #61280
    I will check it out.
  • #61289
    I have tested this, and it works fine. can you send me your JSON file with settings to check it out?
  • #61294
    Here’s my JSON file attached.
    I have not retested this, so am not confident it is a real issue. In any event, my settings are extremely simple and exporting/importing them was not important (although I gather it showed up another issue you are addressing :-). So not a concern/priority for me.
  • #61296
    Queue settings are in there. But, the fixes for the export/import are coming in a new update later today, so maybe it was something related to that.
  • The topic ‘Export/Import not copying Queue settings?’ is closed to new replies.
