Back to Public Forum
Help Seeing Pro Forums
Published on: January 9, 2024 at 11:14 pm · By: Texas Metal Works
Hey @millan, I purchased a couple of the Pro plugins – which are amazing by the way!!! – and I had a couple of little things I wanted to get some assistance with but I’m not seeing the pro forums on the site here. Is there a way to adjust my permissions so I can participate in those? Thanks!
John Pozadzides
Founder, Texas Metal Works
https://TexasMetalWorks.com
https://WeldProjects.com
  • #76961
    Hey John,
    Rhanks for the purchase!
    You have access to the Pro forums: https://support.dev4press.com/forums/forum/plugins/ for plugins you have license for. For some reason, Pro forums are moved to the bottom of main forums page, I will investigate and fix that.
    And you can always access support forums from your dashboard licenses panel for each product: https://my.dev4press.com/products/
  • #76962
    Ahhh! Got it! Thanks! See you over there…
    John Pozadzides
  • The topic ‘Help Seeing Pro Forums’ is closed to new replies.
