Hi MillaN, First I’d like to thank you for this plugin!
I’d like to suggest you a couple of improvements:
1) Notice function like you have in GD-bbpress-tools
2) Custom Class for tag in uploader.php.
For point 1, I did a little change to try:
Version: 1.8.3 — In code/attachmenty/class.php line 9&10
class gdbbPressAttachments {
private $wp_version;
private $plugin_path;
private $plugin_url;
+ private $notice = true;
+ private $restricted = false;
In code/attachmenty/class.php line 41-45
+ if ($this->notice) {
+ add_action('bbp_theme_before_reply_form_notices', array(&$this, 'show_notice'));
+ add_action('bbp_theme_before_topic_form_notices', array(&$this, 'show_notice'));
In code/attachmenty/class.php line 247-259
+ public function show_notice() {
+ $file_size = apply_filters('d4p_bbpressattchment_max_file_size', $this->get_file_size(), bbp_get_forum_id());
+ echo '';
+ echo sprintf( __('Maximum file size allowed is %s KB.', 'gd-bbpress-attachments'), $file_size );
+ if ($this->restricted) {
+ echo ''.__("Your account can't use Attachment, they will be stripped before saving.", "gd-bbpress-attachments");
+ do_action('d4p_bbpresattachment_bbcode_notice');
+ echo '';
In code/attachmenty/front.php line 40
+ add_action('bbp_get_reply_content', array(&$this, 'embed_attachments'), 10, 2);
In forms/uploader.php line 40
– <div class="bbp-template-notice">
– <p><?php echo __("Maximum file size allowed is", "gd-bbpress-attachments")." ".$file_size." KB."; ?></p>
– </div>
<p>
<label for="bbp_topic_tags">
<?php _e("Attachments", "gd-bbpress-attachments"); ?>:
</label><br/>
<input type="file" size="40" name="d4p_attachment[]"><br/>
<a class="d4p-attachment-addfile" href="#"><?php _e("Add another file", "gd-bbpress-attachments"); ?></a>
</p>
For point 2 — I didn’t do any code changes, but I’d like to have theability to pass the class for tag in uploader.php, Example:
<p class="<?php $theclass; ?>">
</label><br/>
</p>
Thanks Again!
Gaston Besada
- The topic ‘Improvement suggestion: Notice class function and custom CSS in uploader’ is closed to new replies.
