Incorrect display
Published on: May 21, 2020 at 5:00 pm · By: maddyssonn
After the update, it became crooked (Screenshot)
What to do?
  • #63644
    https://allskaters.info
  • #63646
    I have no idea where to look on your website. But, based on the screenshot – maintenance mode is active, you need to disable it, make sure to check all the plugin settings, and finally, make sure to clear the cached CSS and JS files.
  • The topic ‘Incorrect display’ is closed to new replies.
