LightBox for attachment
Published on: November 29, 2013 at 1:35 pm · By: Anonymous
Hi, maybe I am missing something or ….
How do I get lightbox to use for the attachments in bbPress.
I am using all the lastest versions and have Simple Lightbox insyalled which works fine on the blog side.
I just can not get it to work for the forum attachment side.
I have seen the setting and have the class and attribute. I filled in lightbox as class and tried both attributes.
Please help, Thanks
  • #21647
    OK, I think I should have “lightbox[singlepic%ID%]” in the REL attribute, since that is also in posts from the blog if I look in the source code.
    But it is still not working. Not sure what to do with the CSS class field, tried several things like: “size-full” and other classes I found, but no joy.
    I use theme Frontier incase that is important
  • #21649
    I use LightboxPlus plugin for WordPress, and for me it works just by adding ‘lightbox’ into REL.
  • #21651
    Thank you.
    Lightbox Plus Colorbox indeed works for the forum also.
    Wasted so many hours on such a simple solution.
    Thank again, Ron
  • The topic ‘LightBox for attachment’ is closed to new replies.
