Like buttons not working on generated lists using shortcodes
Published on: February 9, 2025 at 3:34 pm · By: ralphalpha
Hello –
This is a great plug-in. Thanks!
Everything seems to work fine, except that when I create “Like This Lists” pages, the like buttons do not work on the generated pages.
Here’s one example: (link added below)
I’ve searched and searched, but have had no luck finding a solution.
Thanks for your help!
R.
Viewing 7 replies - 1 through 7 (of 7 total)
  • #578574
    Hello,
    The linked page return 403 error.
    I do not understand what are ‘generated pages’ in this context.
  • #578575
    This reply has been marked as private.
  • #578576
  • #578577
    My IP is usually in this range: 109.245.194.0/24
  • #578578
  • #578579
    The first page: https://music.bloks.net/all-time-favorites/ uses the rating list block/shortocode, showing rating results based on a query, and in this list, there is no active rating block. If you want to have such list, you need to generate it differently, using own query and show active rating block. List based shortcodes can only show passive rating results.
    You can create WP_Query that uses ratings to order posts: https://www.dev4press.com/kb/article/rating-expanded-posts-query/
  • #578580
    Ok. I thought it was something I was doing wrong.
    Thanks again for all of your help and such a great plugin! Great job!
  • You must be logged in to reply to this topic.
