Migrate data to merge with another site
Published on: April 15, 2019 at 5:17 pm · By: eakchieo
I run into a situation where I have to merge my data to another site(also use gd rating system). Is there any tool that I can transfer gd rainting data from one site to another , along with the move of posts?
  • #61115
    Sorry, there is no such tool available. This is not easy to do if the website where you import already has posted. New, imported posts, have to have new ID’s, update all meta, tags, users and on top of all that, all rating, data needs to be updated too. I am not aware of any commercially available backup plugins that can import and merge posts, let alone do it with ratings.
    This would most likely require custom-built merge solution. The connection between ratings and posts (and other rating items data), is in the table ‘wp_gdrts_items’ and column ‘id’ in that table is ‘ID’ in the wp_posts table (when the ‘entity’ column is ‘posts’).
  • #61116
    Thank you Milan.
    Do you have time to take on a customization project?
  • #61118
    I should have some free time next week, you can check out the services page for more information, and contact me from that page so we can set it up: https://www.dev4press.com/services/.
  • The topic ‘Migrate data to merge with another site’ is closed to new replies.
