Quoted replies not working
Published on: August 14, 2017 at 4:39 pm · By: ckodonnell
Whenever I click on the “quote” link to create a quoted reply, it just redirects to my homepage. Any idea what is causing this issue?
Viewing 5 replies - 1 through 5 (of 5 total)
  • #56679
    I have no idea what can do that because Quote link doesn’t have the URL inside, only hashtag. I would need to see the page with Quote button, it is possible that some other plugin is rewriting links.
  • #56680
    Thanks for the quick reply. You can visit this forum post to see what I mean. It’s in a staging environment but a direct and current copy of my site. I have disabled all non-essential plugins and the result is the same…..redirects to my homepage. Thanks for any help, would really like to use this feature.
  • #56683
    I can’t see Quote link, most likely I need an account. Can you send me login info please?
  • #56684
    This reply has been marked as private.
  • #56685
    I tried to debug, but once I click on the Quote, my plugin JavaScript code is not reached at all. After some investigation, your theme has hooked into the A link click and it redirects all links that don’t have website URL. Quote is not a link at all, it is just a hashtag, and it should be left alone. I can’t do much about this, it has to be solved in the theme.
  • The topic ‘Quoted replies not working’ is closed to new replies.
