Shortcode is not working
Published on: January 9, 2025 at 4:24 pm · By: phansheng89
When using shortcode [[gdrts_stars_rating_auto], it returns error:
PHP Warning: Undefined array key “template” in /wp-content/plugins/gd-rating-system/rating/base.embed.php on line 226
I also saw similar issue reported on WP forum: https://wordpress.org/support/topic/shortcode-stopped-working-with-3-6-1/
Hope you can take a look at this.
Thank you.
  • #578548
    Thanks for reporting, it will be fixed soon.
  • #578802
    I had the same error. I was able to fix it by adding this to the shortcode: template=’default’
    Of course, there are other settings besides ‘default’, but that just happened to be the template that I wanted.
    Hope that helps!
    – RS
  • You must be logged in to reply to this topic.
