Showing highest scores for different taxonomy terms
Published on: October 14, 2019 at 2:53 pm · By: petenico
I currently have the shortcode displaying all ratings for my custom post type, but my custom post has a custom taxonomy and I need to be able to display each taxonomy terms highest rated posts as separate tables.
Thanks
  • #62110
    You can specify the term (or terms) in the shortcode to filter down rating list to posts that have specified terms. But that is available in the Pro plugin version only.
  • #62112
    Hi Millan.
    Thanks for your response.
    I don’t suppose there is any way to do something similar on the free version? I already have this plugin being used by my client for some important voting over the next 3-4 weeks and I daren’t run any updates on anything like that at the minute.
    I just want any way of viewing the ratings for posts in a particular taxonomy term, either frontend or backend. Either is fine.
    Thanks.
    Pete
  • #62113
    Sorry, that is strictly Pro version feature.
  • The topic ‘Showing highest scores for different taxonomy terms’ is closed to new replies.
