star rating not displayed
Published on: March 6, 2017 at 2:36 pm · By: uwe76
Hi there, I integrated the plugin some weeks ago and it worked fine so far.
I did not change any settings at all. But now I found the problem that since a few days the rating on the main page is not shown to the visitor any more.
I find this only in one page (what is the main page), while in all the other pages rating is still displayed. And the options in the wordpress editor are also in the right place as before.
Though I did not change any settings at all I tried switching between the display setting without any change. Clearing cache or using other browser did not show effects either.
The page and the logs are still listed in “rating items”.
Any suggestions are appreciated.
Thank you.
  • #55220
    Plugin uses common the_content filter to add ratings (if you use automatic integration from Settings -> Posts) panel. But, with majority of themes, this method was causing problem with the front/home page, so plugin is no longer adding rating into home/front page automatically. If you need that, you can either use shortcode for such page, or to use functions in theme templates.
  • #55248
    Thank you MillaN for the quick response. I try to work around that.
  • The topic ‘star rating not displayed’ is closed to new replies.
