Back to GD Security Headers Forum
Using JetPack
Published on: April 21, 2021 at 4:51 pm · By: rfg1
How would I configure this plugin so that I can also use JetPack to serve images, etc.?
Thank you!
Carson
  • #65775
    I don’t use JetPack, so I have no idea what servers need to be added for what. You should inspect page loading via browser console using the CSP preview mode, and all the servers will be listed in the console as errors and which rule they break, so get all the servers listed, and add them to the appropriate rules in the CSP panel for my plugin.
  • The topic ‘Using JetPack’ is closed to new replies.
