I have already added this on to FAQ for GD Press Tools, but here it is again with more details.
W3 Total Cache is great plugin, but there are some problems that you will get if you use some of it features. If you enable database and/or object caching in W3TC plugin, you will end up with broken cron jobs execution, problems with AJAX on the admin side and in end you will get broken backups in GD Press Tools Pro.
This is old issue, and so far it’s not fixed. I have posted error report for W3TC on WordPress.org forum again today and hopefully plugin author will fix this issue in some future versions. To make things worse, latest 0.9.2.4 adds few more nasty bugs that make use of the plugin impossible for now.
So, if you have backup or cron related problems, please check the W3TC plugin before posting bug reports here in the forum.
- The topic ‘W3 Total Cache Plugin Problems’ is closed to new replies.
